ISC Values
Devilsfutbol17
406
48
Jul 27, 2007
Bellingham, Washington
I have another thread about vacuum/boost leaks, but I only get to work on my car once a week and I figured I would check as many things as I possible can when I get the chance to work on my car(possibly tomorrow). I had huge boost leaks on my injector seals and I have replaced them since my last boost leak test but I'm still hearing a hissing noise over the intake manifold. I'm going to try and do a boost leak test tomorrow and see if they are still leaking.
My question is, what sort of values are normal at idle and at cruising for the ISC steps? I have a logger and am interested on what I should be seeing here. My car rarely idles smoothly, it typically surges and drops real low and will die. My fuel trims are all maxed out as well. I know I need to eliminate all vacuum leaks and I'm working on it, but I'm aslo curious as to if my ISC is functioning properly. I have already tested the resistance and plan to test the motor with a 6V battery. Also my car drives normal, pulls hard, and accelerates as smooth as butter, just can't idle properly.
Also I did notice that on the two times that I stopped today to pay attention to my ISC steps at idle, when my idle was surging and bogging the steps were flucuating around 60-7x before it died. Then when I got home today I watched it, and it started around 60 steps then slowly went up to 120 and stopped, the entire time my idle was absolutely perfect. Thanks
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
  • For sale FIC 1220 Injectors AEM 320lph fuel pump with rewire kit
    FIC 1220 Injectors AEM 320lph fuel pump with rewire kit. 450 shipped to the lower 48 states.You...
    • elocneas
  • For sale 4G63 Bastard 20g
    Bastard 20g turbo Like New
    • arodgst
  • For sale 2g 97 GSX part out
    Ex-wife's project car part-out. Will be updating the list over the next few weeks and adding...
    • Type1DSMr
