93TSI_370K
- 1
- Sep 10, 2011
Elgin,
Illinois
Sorry, this may be a broken record
for seeing this the millionth time.....
Question: After reading a bunch of articles on idle surge and a ton of postings, I am wonder if I have true idle surge (as loosely defined) or is it something else???
Immediately when I start the car the idle is stable but after about a minute the idle is about 1500 rpm and then it just drops like the injectors cut off and then at about 1000 rpm's the rpms pick up again to about 1500 rpm and then it drops again. It repeats this pattern but gradually as the engine heats up, the frequency of it gets slower until finally as it gets to operating temperature, it stops and the idle stabilizes!!!!!! (the tach I am watching is the stock tach in the dash)
The ISC is relatively new, a year maybe two years old, Ive checked the coils on it and they are not open, the TPS is correctly set, I just replaced the intake manifold gasket, the injector insulator seals (that go in the head as the old ones were hard.) The throttle body was cleaned, I replaced the o-rings on the throttle plate shaft.
Question: If it was a vacuum leak, when it reached operating temperature, it would not clear up and it would continue to do this, wouldn't it???
Also, the CEL is not burned out .and does not give a code, so maybe I should take my own advice I have given and eliminate all the components that would give a CEL and concentrate on everything else.
I appreciate anyones input on this.
