Is is my starter or something else?
mitsuclipsegsx
2,561
8
Apr 5, 2004
Dover plains, New York
This happens only in the morning(when its cold), it takes 2 times to start the car,first try it stalls, and second time starts right up?
Honestly, I have A 90 laser rs, and, a 90 ts-i...when it gets cold, i tend to have the same problems, i have asked many people- all i have gotten from them is, "rev it a bit to get it goin' and once it stays idleing...let it warm up for a few minutes" Does you car idle fine otherwise???
I would think it is just from the outside temp. Try a tune up unless you have done one recently.
Mike
Mike
i just replaced plugs/wires,02 sensor,my isc is bad could that be it?
If you know it is bad you should. see if it helps any...cause it is not going to get warmer the next couple of months :p
Mike
Mike
Do you have a Turbo Timer??
My Greddy caused my GSX to stall (it was going bad). It would take me 5-6 attempts to do it so I took it out. Now it's not embarassing to start my car up.
yea i have hks turbo timer,how would that casue it and sometimes i keep the TT off??
My Greddy was off most of the time too.
I did everything to fix it short of buying a new starter - changed plugs, new plug wires, bought a new Optima battery. But it was getting worse to the point that it would not start at all. I was contemplating of selling it due to that problem too since my GSX had given me ZERO problems.
I took off the TT as a last resort and it did fix the problem. The car has never missed a start ever since. The funny thing was the Greddy TT was done right, harness and all.
