Is The Lower Pulley On The Engine Supposed To Move Back And Forth?
BLEWBYU4GOOD
Sep 10, 2002
Need some help here guys!
today my ac belt broke knocking all 3 of my belts off! when i bought new belts and begin to install them. i noticed the lower pulley on my engine moves in and out fairly easy. is it possible that when the ac belt broke and became stuck behind the pulley it broke the bottom pulley on my engine? or is it that pulley supposed to move in and out. it looks like the ac belt and the alt belt go around it. it appears to be plastic. (it is the lower pulley on my engine.) when i start the car with the ac belt unhooked it makes noise because the pullety is wobbling around.
does anyone know if the pulley could be broke and that would let it move in and out or do i need to hook all 3 belts up to stop it from wobbling.
thanks in advance
jack
Lower pulley? Are you talking about the crank pulley? It's possible you self destructed the crank pulley (not too uncommon unfortunately, not too hard to replace but it'll cost $80-100). Find out which pulley it is and report back.
on the side of the engine there are two large pulleys. i am referring to the lower one of the two.. does that help?
thanks for the help man..
jack
BAD!
Get a new one quick, before that one blows up. It has been known to happen.
It's called the crank pulley, get one from mitsu.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
