smills1840
- 365
- 22
- Nov 8, 2011
Blacksburg,
Virginia
Like the title says, is the HX35 going to be overkill for 400whp on a GSX?
I'm really liking the holset turbos, specifically the hx35 for a little quicker spool (from what I read) compared to the hx40.
My build is planned out like this:
This build list is in no way set in stone, so PLEASE feel free to replace any parts listed below with other parts!
HX35
BEP .55 housing
PR ex mani
Recirc O2 housing with Tial WG
3" turbo back
FMIC
Walbro 255 rewire
1000cc + injectors (still reading up on which ones to go with)
DSMlink V3
My main engine question is: Will I need cams? I am not completely opposed, but unlike many others, I don't like a lopey idle. But I'll probably sacrifice the sound if it means big gains.
And of course all other supporting mods:
Bolts/hardware
gaskets
head studs
etc.
Suspension:
Koni Yellows
Ground Control Coilover kit
Prothane Total Kit bushings
Sway/strut bars
Timing belt and full engine gasket rebuild was done ~2,000 miles ago
No balance shaft delete, haven't decided if I'm doing that yet.
So my questions are:
Will this setup be overkill for 400whp? If this will do more, that's awesome! But my goal right now is 400whp.
This setup will maybe be tracked once a month, if that. It will be purely a street car. It's also my DD. Will this setup be streetable? I know there are a lot of factors that play into this, but is this a pretty reliable looking setup if done right?
Thanks guys, and I am 110% open to criticism!
HX35
BEP .55 housing
PR ex mani
3" turbo back
FMIC
Walbro 255 rewire
DSMlink V3
Bolts/hardware
gaskets
head studs
etc.
Suspension:
Koni Yellows
Sway/strut bars
It spools nearly as fast as the 18g I ran. Its torquier before full boost because it moves more volume at a lower pressure than the 18g did.
