dsm-onster
DSM Wiseman
- 8,592
- 132
- Jul 11, 2004
Bloxom,
Virginia
If you knew the background, you would know that "voodoo" refers to really making it work, where as Andy really hasn't in his personal educational endevours, though comical guarantees of results on his part have been subsequent to his classes (which many of us have already thoroughly completed). And, the math supporting it only shows that opinion flows in math just as well as any other view point. . . The only thing that stands out here is truely the great empirical data by Glenn. And math that supports it doesn't mean math works half the time. I have plenty of math and supposition as a consequence supporting the rate of absorbtion of the heat with highly atomized methanol vs. a good intercoooler and it's specific heat. But that's all math and opinion.
Results are this: the intake manifold sweats after meth injection of proper amounts, and never does before. Therefore, only the introduction of the substance accounts for the sweating. Why would a substance introduced make the aluminum maifold sweat, which constitutes the same material as an intercooler; and not supercool the air to which it was introduced with a much better absorption property (higher specific heat)? Simple logic is what's being thrown around, since math is the useage of the thread. So answer to yourself what is the heat absorbtion value of aluminum, the surface area of the aluminum in question and the surfaces value and heat absorbtion of the mass airflow and methanol injection in question. How can the air NOT be colder than the suroundings when the manifold sweats?
It's all voodoo, unless you give a scientific equation to prove otherwise according to the above. And further contributing to voodoo, what was Lucas English's total nozzle size? Actually, what was his total airflow?
. Certainly not what you REALLY think is the reason.
