1G Interior wiring harness questions
911gdsmboostin
388
23
Sep 5, 2014
Irwin, Pennsylvania
Hey guys feel bad starting a thread for this but I can't find any type of info for this one.
I'm working on putting a new engine bay fuse block harness on my car as someone hacked the old one. Running the wires inside on drivers side and everything has it's place except 1 connector that is part of the interior harness.
Neither of the wiring harnesses I have has a plug for it and I'm unsure what it's for or if i need it. Honestly would just like to know what it is. This pic its hard to tell where it is but its directly behind the driver side fuse block the engine bay harness has 2 plugs to go to this area and plug in 1 connector i believe to be a 16 pin the other like a 6 or 7 pin then their just this lone 3pin.
Any info would be nice thanks.
Well there is this post. http://www.dsmtuners.com/threads/the-1990-engine-control-wiring-harness.412841/#post-152709637 I assume if you cannot find it on this one there might be a larger issue.
This one may be helpful, it has the right area. I'll have to read through it after work. The only issue is its not talked about much. It's the harness that goes into dash and the main fuseblock and goes everywhere inside the car. Its just 1 lone connector and i feel soposto go to somthing.. but i have no clue what
I know I checked a few aftermarket sites that sell connectors and I couldn't find one that matched up. A wiseman will be helpful, but maybe by process of elimination you will be able to find it. I find it funny after all this time I am still in Probie status. Most of the time is because I find answers after digging LOL
Likely an intermediate connector involved solely in the ABS system. If you have a FSM, it would be connector C-68. It would have:
[01][XX][XX][02]
[03][04][05][06]​
Pin 2 - Gray, involved in operating the ABS light
Pin 4 - White, wire running between front left ABS speed sensor and ABS control unit
Pin 5 - Green, other wire running between front left ABS speed sensor and ABS control unit
[01][XX][XX][02]
[03][04][05][06]​
I appriciate the input. Never gave that a thought. If it had abs it doesnt now. Hopfully thats what it is.
