Interior harness wire identification
KFred 513
146
Oct 11, 2012
SUllivan, New York
So I spent a little too much time away from my harness relocation. I have a wire labeled volt gauge, and a wire from my oil pressure gauge also labeled volt gauge. Not sure if I messed up the label, or labeled the oil pressure wire by mistake rather than a wire from the volt gauge.
The wire i need help with ID is a yellow wire with a pink stripe. You can yell at me for not having a FSM and rewriting the whole car, but I kept good track of everything(except this).
A diagram made by Eric/Turbosax shows the connector which houses the wire
The wire in question is yellow, #50, on connector B. I confirmed with an ohm meter that this is the other end of the unknown wire.
Can anyone tell me what this wire does? Thanks in advance
It runs between the oil pressure gauge in the dash and the oil pressure gauge unit sensor on the oil filter housing.................................................C-25, 90-142
Thanks for the quick reply. I'm assuming the AEM output was wired that way in hopes that the OEM gauge would still function. It never did, so I probably won't hook that back up
