Interior Harness ?'s
Stmguy42
89
May 17, 2012
Greenfield Twp, Pennsylvania
My 1995 talon tsi 5 speed no sunroof has started to rot out. So I bought a 95 gsx with sunroof. My question is is the interior wire harness the same for a 95 talon tsi with no sunroof the same as the one as the gsx with sunroof? Is the 95 eagle talons set up so so all i have to do is add the sunroof wire harness , relay's and fuses? Or do i have to buy an entire no interior harness?
Your harrnes will work fine but you will have to add the wires and relay for your sunroof if your dead set on using it or you could just leave it there and not use it.
thank you, i will have to replace the tail light harness though right? cause the set up of the talon lights are different then the eclipse
