turboglenn
- 6,375
- 124
- Nov 5, 2007
RIpley,
West Virginia
NOw i'm not going into airflow,vs. air temp, pressure drop ar anythign like that. I want to just get some basic info together from some of you guys/gals that can monitor/log your intake air temps.
As an example i'll throw mine out there
t3/4 turbo 57 trim, busher old style front mount ( the trianlge loking one with the endtanks both pointing to the pass side. I believe it's 24x8x3.5 and 2.5'' IC piping.
On colder days in the 40's and below i see almost no heat gain, it may go from 41 on start up to 50 or so on a long hard pull at 18-19psi.
On Hot days. 85+ with humidity in the 70% range most of the time ( if not higher) I go from about a 95* temp. And after a a few repeated third gear pulls im only getting 127-131 ( sometimes a TAD higher, but not by much)
In all examples of my temps, I figure idle temps are higher because of heat soaking of the piping, manifold, tb and IC from engine and outside heat. My IAT sensor is in the intake elbow for teh throttle body.
what are some of your guys readins on various situations?
. I know my temp on like a 80 degree day was like 68 degree.
