Intake Upgrade
Superfly4943
58
Jan 14, 2008
Charleston, South Carolina
actually the t-body hole is about 64mm across so it doesnt fit up perfectly but it does fit without hitting a lip that can cause any turbulance going into the plenum :thumb:
AMM
I do know that modernperformance.com makes a bolt on 60mm. vry nice,and you can always bore the hole in the intake out if you had to ,just thought you mite check it out,,good luck,,,,viper99
hey as of today this thread is exactly one year old............ and i think the OP was referring to the MPX thorttle body to begin with sir (the 60mm that is).
mike
