intake snkorkle / pvc question
ak47mopar
Oct 26, 2008
farwell, Nebraska
ok so my intake snorkle just has a hose coming off and running open to the back of the motor. it is blowing oil at boost/higher rpms all over the tranny then thats covering the drivers side of my motor. shoulnt this be hooked up to something. the things that have crossed my mind are pvc valve trouble and head gasket. also scence the problem has began my pil psi is just fluttering at 40 psi during highway speeds when it used to be around 60. any thoughts would be nice.
basicaly what im wondering is what the plumbing should be on these 2 items bc the guy who owned the car before me just halfassed stuf so i dnt no what it should look like.
also i might ad hat my car boost extremely fast like 15 psi as soon as you tap the gas goin down the highway and if i let off the trottle it will vacuum around 10-15 and at idle its like 5 to 10 vacuum
Im not looking at my car right now but from what I remember the bigger hose hooks up to the valve cover, one to the boost control seloniod and the one that your talking about goes to like another sensor or t fitting!
the bsc is removed the snorkel or line coming off the left of the valve cover is the one ran to the back of the motor and goin nuts. the charcol filter and that has been removed.
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
