94awdcoupe
- 1,416
- 217
- Nov 6, 2004
tampa,
Florida
not using it anymore. I was running the BAP when I was running one set of injectors and pump gas. I wanted more fuel without having to switch to larger injectors. you can get a tonne more fuel/better tune by running your injectors on the BAP as well. the BAP is the same thing as the FIC easytune. its a voltage regulator. you can run the injectors at the 17.5 volts and you will get more fuel . it will eliminate the need for an accurate battery offset table. you will get a cleaner idle as well.
I ended up switching to 6 injectors. the primaries (main tank, 93 octane) now run off a quiet reliable evo 9 pump. that pump can supply enough fuel for 375whp. then the second two injectors run on e99 and a walbro 255. (boost activated) they supply enough fuel for 175whp. I only run 465whp and dont ever plan to exceed 550whp.
