XC92
5+ Year Contributor
- 1,654
- 376
- Jul 22, 2020
Queens,
New York
Basic question. I just got a new OEM clutch slave cylinder that I hope to install in my '92 Talon TSi AWD today. The old one was leaking air and thus no good. To make it easier to bleed I bought a pair of Russell speed bleeders, which I'd previously installed on all 4 brake calipers and which have worked out well.
Thing is, they come with a coating of some graying substance that I'm not sure whether it's there to help seal the threads against leaks, make it easier to install, serve as threadlock, etc. And when I started screwing it into the slave cylinder bleeder opening, it met with resistance almost right away, due to this substance I assume.
So I'm wondering, am I supposed to lubricate the threads, with say brake guide pin silicone lube, or brake fluid? Or install it dry, as is, and don't worry about the resistance?
