99gst_racer
Moderator
- 12,009
- 1,695
- Apr 5, 2003
Coloma,
Michigan
The prupose of this thread is to discuss these two styles of automatic bleeders.
#1: Speed bleeder. This is the more common design. This is an offering from Russell.
Likes: Simplistic design, moving parts are all internal, more common to find "in stock"
Dislikes: Relies on thread sealant to not allow air in while bleeding
____________________________________________________________
#2: Solo-bleed. This is the less common design. This is an offering from Earls.
Likes: Seals air out right at the bleed hole in the caliper.
Dislikes: Seems like the brass plunger could eventually wear out and/or deform after several cycles of use. Less common to find "in stock".
