installing injectors, bad dea?
619dsmer
41
Apr 30, 2004
san diego, California
What it be a bad idea to upgrade my injectors when my car is pretty much stock?
No, but it wouldn't really benefit you until you have an upgraded fuel pump. And unless you have an SAFC and a logger, you won't be able to tune your car, and it'll run like crap. :D
This might be a little ahead of things for you but, if you do decide to change injectors. Make sure that you use fresh o-rings and make sure that you don't kink them in any way, they will leak. But like psychlow said, unless you have more fuel oriented mods done, it will be kind of useless. Check out the upgrade section of this site, or others. They will give you a good idea of where to go with your car. Plus it really helps to know what you want from your car too.
www.buschurracing.com
www.roadraceengineering.com
These are a couple of sites that you can get some ideas from. Good luck.
