installing gauges, Not like other threads,
miliman13
2,531
723
Jan 1, 2011
tampa, Florida
ok before any one try's too reprimand me, i did look at all the other similar threads. NO i DO NOT NEED HELP WITH electrical wiring, were to wire it or ground it,
what i need help with is the senders. were do i install the oil pressure sender. oil temp sender. and water temp sender ? .. any pictures ? because i learn with PICTURES OR DRAWINGS im SLOW!. thank you all for reading,
For oil pressure unbolt the old oil pressure sender, and screw in the new one.
For oil temp, drill a hole near the bottom of your oil pan and weld a 1/8npt bung to it.
For water temp, tap a 1/8npt hole in the thermostat housing or use the hole from the original sensor.
But unless you're putting down big numbers, I would use only the oil pressure.
    • dsmmario
    • Detail
    • dsmmario
    • Canadian_CD9A
