Installing FIAV bypass plate on 1G GSX
925BoostKid
Feb 15, 2014
San Ramon, California
I need tips on installing a FIAV bypass plate in hopes to cure my idle surge problem. What should I look for and things I need to be aware of when installing? Thanks in advance !
Bought a used tb and block off plate. Used the rubber isc gasket, and made a gasket using felpro gasket paper. Isc-rubber gasket-plate-paper gasket-tb. Not sure if I did mine correctly, but it's working.
Best to use a 1/4 inch ratchet, proper Philips screwdriver sized bit, 1/4 adapter to keep pressure on screw while loosening screw with ratchet.
    • Sdcryan1
