Installing a MBC Without a j pipe nipple??
GettinPaper
289
Aug 31, 2009
Battle Ground, Washington
I just bought a used 20g turbo and was wondering how i would go about hooking up the MBC now. Since i won't be using the JPIPE anymore, and i don't know where else would be the best place to put it.. Any help would be appreciated..
Thanks
Why wouldnt you use a j pipe? What brand is your 20g?
You could always tap into the compressor cover and to to a hardware store and find a fitting and make your own nipple..hope this helps good luck.
Closest point you can reasonably tap for a pressure source to the wastegate. Compressor cover, outlet pipe, part of the ic pipe. Lots of options.
Yes thats fine, you want to tap in to the closest point to your turbo. Lower Intercooler piping is sufficient. The ebay turbo on the other hand, may not be.
Well i have all the supporting mods for a bigger turbo..
I just can't find one around here at all for a decent price..
So my buddy sold me his knock off 20g for 75$..
For 75$ i will rock this thing till it blows then slap my 14B
back on if it comes down to that.. But the turbo looks like its in great
condition.. We will see when it's on the car ;)
Thanks for your help guyyss
What i did is found a brass 1/8" npt nipple
3/16" x 1/8 npt hose barb nipple fitting brass | eBay
Then I drilled a hole in my aluminum J-piping just a tad smaller than the fitting, so it cut its own threads when i used a wrench on it, screwed it in to cut the threads, screwed on a thin brass nut from the inside then used a little JB weld to make sure it was all sealed and snug, and wouldn't go anywhere.
I'd assume the LICP would be the same deal.
i must live in the podunkest part of butt-fu^$ egypt there ever was, theres no one within literally 50 miles of me who was comfortable welding my j pipe with an aluminum nipple, even the "welding, machining, and fabrication" shop up the road. My fingers are crossed, hopefully my nipple holds...or it needs to be clamped tighter ;-)
If you didn't want to drill and tap you could always use one of these
Turbo Quick Tap Fitting for Boost Source
Not sure how well they work though :hmm:
My turbo pretty much looks just like that LOL.. but not as big of an inlet
Does anyone have any inputs on these tap fittings into
the couplers? I am debating on doing this..
So i was just checking out my turbo and noticed a random bolt on the flat
side of the cold side of the turbo.. I removed it and it goes all the way through..
I attached a picture to show you where the bolt was until i removed it.. Is this where your suppose to tap your MBC for this turbo?I have no idea LOL.. That's why im on TUNERS :)
Any help is appreciated :D
Anyone???
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
