mbc with no j pipe nipple
dsmxfan
58
Feb 7, 2011
kettering, Ohio
can i use the nipple thats double circled for the pressure source to my mbc? my j pipe has no nipple so i was just wondering.
thanks in advanced!
No you can't. It has to be a post Turbo nipple. You can T into the fpr vacuum hose Or use one of the nipples on your intake manifold.
I thought id elaborate! Lets say you set the MBC to limit your turbo at 16psi. The boost source you tap into will be what tells the MBC what pressure your turbo is creating. If you tap into the intake before the turbo, the turbo hasn't compressed the air yet so there's no positive pressure. Your MBC has no idea what pressure your turbo is pushing if its set up to sense air before the turbo has pressurized it. So while its waiting for the 16psi to build up in the intake (which it never will) so it can tell the turbo to stop, your turbo will be going nuts. aka boost spike, which is bad.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
