J-Pipe Nipple
1 x 1/8 npt (national pipe thread) tap.
1 x 1/8 npt to 1/8" fitting.
Drill bit set, start small and finish with 11/32".
Tap near the flange so you can dremel off excess fitting. Autozone, Pepboys......etc. will have what you need.
2bclutch said:
I will do some searching around locally for sure. Just wanted to make sure the sizing was correct. :cool:
Try and get a 1/8" fitting, 1/4" is bigger than most fittings on a mbc.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
