Installed new battery weird issues.
Chris95GST
224
Aug 12, 2003
Okay, well to make a long story short my car has been out of commission for a month due do and SAFC being stolen and in that time period I've upgraded to DSMlink. Now after installing DSMlink I noticed that when I tried to start my car the battery seemed dead since the starter couldn't get a good start. I replaced the battery and now every time I put the key in the ignition the wind shield wipers turn on (I can't turn them off) and and the radiator fan does to and it doesn't even sound like the starter motor is going. What could be the problem. I can't think of what I might have messed up wiring wise.
check all your fuses. did you tune it yet with dsmlink? if so and your battery dies or you change batteries the ecu erases the tune. so does your car start? maybe you had a bad starter all along?
did your car ever run right with dsmlink installed? when you got ## ecu socketed did you send it in to dsmlink or have someone else do it?
It has not ran with DSMlink installed, but I had DSMlink socket it and it should be okay. I should check my fuses though is there on eit particular that would cause the issue I'm having?
I found what I'm pretty sure it is. The 100 amp Alternator fuse is blow pretty baddly and is stuck in there. I can't get it out to save my life though does anyone have any tips. I've tried pliers etc, but it won't budge. I think it is fused in there to a degree. Never mind moment of stupidity.
