Still gaving Battery issues, new part
twstedturbo
Nov 1, 2008
Satellite Beach, Florida
Make this simple and easy. Found the source of the first drain. NOW i have 2 new issues. The effin power windows dont want to work and more, either do the door locks. And when i turn off the car, and then get back in, the radio keeps resetting itself. wtf could this be now?
Thanks
Stoopid car, BUT i just took it for a run on 95, runs nice n sexi. Headlights work, along with everything else. EXCEPT no power windows, and this sucks. I live in FL and the AC isnt hooked up. im not that worried about door locks but I am sure they are attached in some way
:notgood:
FAIL LOL
it better be. LOL i didnt take apart the door LOL. I was having serious eletrical drain. But now its growing into more and more issues. It started as something small. ugh.
Well 75% of all electrical problems have to do with a poor ground. Even a draining problem. When the battery and other devices are not grounded properly a voltage trail will backfeed through other devices to find ground. So if something is controled through the ground circuit it can possibly be switched on just due to the fact that something else needs a ground.
I did have a bad ground within the dome light system in the car and i took out the fuse for that and it SOLVED for the time being. But now im having those issues and Im thinking they all need to be tied in together, I JUST went and ripped the door panel apart and the switch is good and light n such. The car starts without problems. The radio works when i even put it on ACC, it just resets itself. And no power windows or door locks
Radio reseting is Due to the Constant hot and Switched Power wires being reversed or Both hooked up to a Switched lead at the fuse box...
I bet you have the first, Being your radio power wires are wired in backwards.
its a stock radio. everything electrical is stock except a boost gauge but that gives me a idea on something.... thanks
Well it wasnt what i was thinking, and the 80A Fuse is good. Still at a loss on this. But i just realized that I have no HVAC stuff either. But the power seatbelts that love to strangle you alive still work.
So do the interior lights.
Check for parasitic draw. By disconnecting your negative battery for 30 minutes. Then connect your volt meter to the negative battery terminal and the negative battery cable. It should be no more than .005amps. If its more then you got a problem. Then just start pulling fuses untill you find whats drawing the power.
A easy way to fix this is just to cut the wire to that fuse and wire in a relay.
.001 draw i did that like 2 hours ago LOL.... I dont have so much of a problem anymore of a draw, now my Power Windows and Door Lokcs dont work, My blower motor doesnt work (HVAC), and my radio doesnt hold memory, as soon as I turn it on, to acc it comesright on but its not holding the memory. Its all stock except the boost gauge. ive gone through the fuzes under the dash and in the engine bay to no sucess. I found a drain with my interior light switch on the roof of my car, I just pulled the fuse for Dome light and it fixed that issue but now like I said i am missing alot of other crap. and im confuzzled
:banghead:
ITS FIXED..... all thanks to this little post that i stumbled across by accident. http://www.dsmtuners.com/forums/pro...-heater-rear-defrost-windows-c-cd-player.html
now why the HELL does the power windows, radio memory, power door locks run off of this???? LOL whatever its fixed and im going to sleep a good night after 4 nights of hell. I have my front fender ripped of the car starting to run wires back from the fuse box LOL.... freakin car.
and that fuse wasnt even blown. just it didnt like it...
NITE and I hope others will find this as there fix.
