inner throttle body gasket
mndsm1
88
Apr 22, 2008
Prospect Heights, Illinois
does anybody know which way the inner throttle body gasket is supposed to sit(between the throttle body and intake manifold) ? i just purchased a new 1 today...put it in and its still leaking from that area, which means its obviously in the wrong position :) just wanted to know which way it should sit before i take this thing apart again and do it the wrong way...also im wondering if i should use copper spray just to make a for sure seal.
no spray . Just reference the marks left on the gasket from first attempt . What throttlebody do you have , stock ? Different gaskets for different years . And are you sure it isn't the BISS or the throttle shaft seals ?
The gasket only goes one way. Either upside down or right side up. Only one way works. Rookie is right, you need no spray. Take a bottle of soapy water in a spray bottle and spray it over the throttle body while doing a boost leak test. Then you can see if it's the BISS. If it is the BISS screw leaking it's most likely the o-ring around the screw itself.
There are circles outlined on the gasket that match up to the vacuum ports on the throttle body. When you have those circles of sealant on the gasket lined up with the holes it will become obvious. Then you got it.
And just like rookie said ,you may have the wrong gasket deppending on the year.Not saying you have the wrong one but heres a link that could help in later on.If you want to know the difference.
DSM THrottle Bodys
are the studs on the intake manifold removable?
It doesnt matter what 1g bc there the same intake just the tb year.And yes you can take the studs off .There on there tight but they can come out .Use visegrips and there you go .:thumb:
so i take it that i have the right gasket just that i needs to be lined up differently? oh and thanks for your help
From what tb you said you have and what gasket yes.As for lining it up .Like someone already said theres only one way it can go on.Maybe you have a leak somewhere else.I would make sure the gasket is ok if you put it on then took it off .And put it back on then, do a boost leak test right at the tb and see if you have a leak somewhere in the tb or intake manifold.Then go from there.
which way does this gasket go ? which side goes towards the intake manifold
The side that is up in the pic should go towards the tb.Thats like a lil rubber lining . You want that to go to the tb.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
