Injectors for a 50trim
xEM1x
78
Nov 9, 2003
York, Pennsylvania
What size should i go for a Drespec 50trim, has a stage 5 wheel. Little more lag/more top end type of turbo.
FIC 650cc or 750cc?
:talon:
You always want to go one size igger than the one you want. So i would say FIC 750's thoe are the ones am getting as well
Why would you go one bigger? It is not needed. You can run a 50trim all day long with 650's. It is up to you though.
650's will be perfect. I'm just running out of fuel at 20psi on 550's, so when I get these PTE 680's.. I'll be in overkill territory. :D
Exactly.
Why do people buy things bigger than needed? I run a TDO6H 20G that flows about the same as a 50trim. I am at about -28 on the S-AFC II and still rich.
Ive decided on the 680's from PTE as well. $309 shipped from extremepsi.
I agree with 660 range injectors. They will be plenty for you. Also If you plan on using an SAFC to tune, then you'd really be pushing the limits of the SAFC with anything in the 700's.
midnght said:
Exactly.
Yup. People may think bigger is always better, but when you have to tune down the AFC that much, or more, it really makes things a pain. Go with the 650s and you will be fine.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
