2G injector wont pulse
cartae11
Oct 19, 2011
chetopa, Kansas
ok i have a 95 tsi and i have checked everything i can think of and still no fuel is goin through the injectors. I have fuel to the rail but not through the injectors. can someone please help. the car ran fine then one day it wouldn't start.
Make sure CAS (behind intake cam gear on 95-96) is working as it supplies pulses to ECU to fire injectors. Do you have any voltage on injectors? If not check injector resistors. Finally look inside ECU for leaking capacitors.
i have 12 v to the injectors but the car was running one day then the next it wouldnt start. i checked the ecu looked ok. cam sensor is new but i have spark cause it will start if u put staring fluid in it. i have no idea now
Check your grounds and wires. I know a lot of vehicles run constant power to the injectors and they fire by grounding them. I will bet either your ecu. Took a crap or you have a bad ground somewhere or a broken wire. Having power at the injectors is only half the battle, take a dvom and check for continuity from the injector clip to the ecu harness plug. If the wire is damaged it will tell you.
not sure how to check for that on the ecu harness. i have checked grounds. so i am stumped big time just wish someone has had this problem and was able to fix it.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
