injector sizing for t3t4
That turbo can flow about 600 CFM of air I believe. It will depend on what type of fuel you are using, but on pump gas I would say go for somewhere in the neighborhood of a 750 - 850cc injector.
what size injector do you guys suggest using on a t3t4 to4e?
:rolleyes: Can you be any LESS specific?
What compressor wheel spec? What turbine wheel spec? What turbine housing spec (flange type and a/r)?
57 compressor wheel trim
.50 a/r compressor
.63 a/r turbine
A 57-trim is rated at a shade above 50 lb/min peak, so you'll probably be seeing airflow around 46-47lb/min at 20-22psi depending on your supporting mods.
A set of 750's would work, but 850's would allow room to grow assuming you'll want to one day run more boost. This depends on what fuel you'll be using as well as what you'll be tuning with- you can't tune anything larger than 650's with an AFC, for example.
sorry no picks the car in Norfolk i got few to Chicago or school for the navy. and no!! it is a garrett the only thing ebay on the whole car is the wast gate and manifold that has been ported to hell and back that came off of my buddy's 2g.
and i will be running 93 in it with a walbro 255 and ecm link as soon as i get taxes.
I run mine with 680s at 23-24 psi but my idc s are pretty high too so go with 750cc our bigger unless your using dsm link to tune then go big and you will only have to buy injectors once.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
