Injector size and fpr
Tsisaman
39
Feb 11, 2013
Jamestown, New York
Hey guys sorry for all the dumb question to tonight. I bought my car off a guy that did some work to the car and did kinda a half ass job at that. I've looked and looked and can't seem to find out if there is a way to tell what injectors are in the car with out sending them to get flow tested and also just a quick question on the fpr what number should I be looking for.
Post a picture of the injectors.
Base fuel pressure (with the vacuum line disconnected and plugged) is:
1G auto - Spec 42.7psi (Standard value 41 - 46 psi)
1G manual - Spec 36.3psi (Standard value 36 - 38 psi)
Ill post a picture when I get home is their anything I can look for so just in case I can't get a picture up tonight
And thanks for the help man
Like Snowborder said if they are OE 450 550s ect they are color coated. Aftermarket parts you will have to find some kind of code or brand.
Btw I seen you are in Salisbury right down the road from me. If you end up needing parts Look up miller import parts he is here in Kannapolis and specializes in used DSM parts
I'm up in ny for a few more months but when I get back down there ill defiantly look him up.
Thanks for that man
does anyone know what size injector these are.
