injector size
daveeclipse99
74
Dec 10, 2008
grand rapids, Minnesota
im running a t3 t4 .50 trim turbo ... what size injectors should i get ? i have a aem stand alone so i can change injector pulse if needed .. i have 370cc accel injectors but in thinking they will be too small .... what size and brand should i go with
thanks :thumb:
yes i have a 420a .. its bored .30 over wiseco pistons, crane turbo grind cams ect . i am getting a walbro 255 fuel pump also ... i am having a hard time finding injectors for a 420a ...
Just get some 1050ccs or 1100ccs and be done. Lol, just throwing some numbers out there. We need some more info.
Depending on what your using to tune, I would suggest something in the 650-680 cc range. I think that would be perfect for around 20ish psi on a 50 trim. If you are tuning with dsmlink or something eprom based though, I would go as big as you can afford. Its always easier with those type of setups to go bigger than you need rather than smaller.
I don't have experience with e-85, but if that's going to be used you would definitely need larger injectors. I was just assuming that it would be on 93 octane or something similar. I forget the exact number but you need a certain percent more fuel with e-85 to match up with the effect of unleaded. Maybe someone with more experience with e-85 can chime in. Also don't forget that with the wally 255lph pump you will need an afpr. You may have known that but I didn't see one in your profile so just thought I'd throw that in as well.
im shootin for 400 hp ... i have a megasquirt engine management system . anyone know any brands that work for the 420 a ?
