1G Injector Resistor box with Motec M400 ECU?
Adrianchino
Aug 1, 2019
Whittier, California
Hello all, new to the forum.
I’ve looked through the faqs and couldn’t find anything( before I hear uSe tHe seARcH bUtTOn)
I’m running 720 cc low Z injectors on my 1G Eagle talon
Problem is, I wanted to puchsee high Z injectors but found out that I don’t even have a resistor box.
It already has that resistor box plug delete.
Also, I’m running a Motec M400. Don’t know if you can change amperage to the injectors through this ecu. Measured injectors to verify it’s low Z and it is.
I thought my injector drives would have burnt to a crisp by now.
Should I buy high Z injectors or lowZ?? Don’t know what to do at this point. Obviousness points to purchasing low Z injectors but idk if that correct.
MoTeC are made with peak & hold driver outputs. Peak & hold drives can drive saturated (high Z) injectors too.
  • Wanted 6 bolt NT water pipe
    • chrisman287
