Resolved injector resistor box???
pearl4gtsi
223
7
Jul 17, 2004
yonkers, New York
ok, so my car started runnning rough yesterday, missing pretty bad. checked it out and found out that injector #1 is not firing. swapped out my injectors and still had the same problem. got my wiring diagrams and went through it. tried swapping an ecu. no difference. with a test light i checked each injector plug. each has a pulsing ground signal ( which comes from the ecu, i believe ) and a constant power. injector one has the pulsing ground but no power. used an ohm meter and tested the injector plugs. got the same on 2-3-4, but 1 is way off. so i went back to the wiring diagram. the mpi control relay supplies power to a resistor, which in turn supplies the power to the injectors. the ecu controls the ground which pulses, hence the injectors pulsing. so i believe my problem to be the resistor. problem is, i dont have the slightest clue where it is?!! can someone help me out here? i have the test procedure to test it but when i searched both here and google among other sites, i dont know where its located. need my car, its my only way around. please help!:confused:
I had a similar problem with my 2G. I don't know if the resistor pack is in the same place but mine was on the firewall just under the intake manifold.
This link shows that it is just to the right of the battery.
http://www.mitsu-media.com/showthread.php?t=9198
Go to the second post, its the second link.
http://members.shaw.ca/dsm.1000q/Eng...1G/respack.htm[/IMG]
  • Wanted 6 bolt NT water pipe
    • chrisman287
