420A Resistor box ?
Inkdlyfe
438
8
Feb 23, 2016
Summer feild, Florida
Alright so I'm planning on turboing my car again here soon but how would I tell what injector is bad and how would I tell if my resistor box is bad ??
What do I need to get inorder to not have to run a resistor ??
Ok so I get how to clean and test them but I didn't get the answer to the other do I need the resistor box for the injector or no ? And what could I get or do to delete it. I seen something bout the plug and being cut but I got a factory harness which isn't cut
Low impedance injectors need a resistor box.
High impedance injectors do not.
If you get high impedance injectors (aka high Z) you don't need the resistor pack. Stock 420As come with high z injectors. Some one must have put low z injectors in it and that's why they need the resistor box.
Low z injectors typically cost less which is why people go with them. look at FIC's website for more info on low vs high z.
  • Wanted 6 bolt NT water pipe
    • chrisman287
