snakeyes711
- 646
- 0
- Feb 5, 2009
W-S,
North Carolina
reant on!!! I'm pretty pissed, I got a injector kit and went to install it today got it all apart and realized these hard plastic tips for the injector were like twice as long as the old ones. I called them and told them, he said cut them, pretty much your on your own. As thats the part number that pulled up for your car.
So I attempted to cut them to size, first trying to save the old ones. That was impossible as they were so old, and hard they just shattered into pieces .
I thought about just leaving the old ones on. The newer seal just slid over it real easy, too easy I figured thats not going to seal. So the first one I cut I held with some pliers, and used a small mac tool knife, it shot off on the floor when it cut , actually it only cut a small bit, and broke the rest of the way. luckily i could trim the broke section back flush with the rest instead of the other way around.
It was pretty hard to get it on the injector because they are tapered on the end, and cutting half off only worsened it. Which is why when I cut the last two, and tried pressing on they broke down the side, and now there is a big section missing on the side of the injector. How the #### is that shit supposed to seal, I'll never buy parts from them again, I'd rather make parts then buy anything from them
.....rant off.
You know I looked at some other injectors that has a long tip on them, I'm wondering why are these short?....
I thought about just leaving the old ones on. The newer seal just slid over it real easy, too easy I figured thats not going to seal. So the first one I cut I held with some pliers, and used a small mac tool knife, it shot off on the floor when it cut , actually it only cut a small bit, and broke the rest of the way. luckily i could trim the broke section back flush with the rest instead of the other way around. It was pretty hard to get it on the injector because they are tapered on the end, and cutting half off only worsened it. Which is why when I cut the last two, and tried pressing on they broke down the side, and now there is a big section missing on the side of the injector. How the #### is that shit supposed to seal, I'll never buy parts from them again, I'd rather make parts then buy anything from them
, I threw the hand in for Sh*&s, and giggles.
