Race94
- 1,151
- 0
- Jan 6, 2003
Puerto Rico
Hey guys,
i recently put in a clutch wich was dead and my car is running pretty damn good, i've raced against a slightly modded srt-4 and we were side by side till 3rd gear, also raced a T4 turbo charged, cams, frontmounted etc. GST from a 1st gear roll and i was ahead till the end of 3rd gear by 3 cars since the turbo spools up so fast.
Thing is at higher RPM's and speeds the turbo seems to die off, i guess since it's a small turbo. I have no fuel regulator but have a fuel pump and run 16psi easily.
Is there any way to get more efficiency and speed up top with the 14b? Maybe fuel regulator? I don't want to go with inyectors cause that consists of S-AFC or some other type of management.
Also what's a good turbo with similar spool up time and good top-end?
big 16g? t3/t4??
i want to upgrade at once but i want a fast spooling turbo that will hold his ground up top, even tough i think neither 16g or t3/t4 can spool up that fast, well thanks.
big 16g? t3/t4??
