ignition switch wire coloring schematics
KeelesKustome
882
17
Dec 29, 2007
Waverly, Tennessee
i need some hlep guys, we have traced my no power all the way back to my ignition switch area.. and noticed, the actual switch on the left hand side of the steering coloum seems to go from 1 plug connector into the switch area and then it splits into 2 plugs.
the first is plugged in ,and the second is comming out off the first and it has a red blue and green heavy guage wires, that keep a constant 12 volts,,,,, it just so happenes that my mfi relay, my ecu, my security system could all 3 use a constant 12 volts, that they are not recieveing......
we can only assume this ignition wire should be plugged in somewhere, although for the life of us we cannot find the spot......... any hekp with pictures would be preffered to see where this should go,, i am woundering if i am missing another piece or something.
One plug is the actual switch, the other looks to be for the key reminder. Do these look the right plugs that your talking about??
i don't think so.
the actual electrical part of the ignition switch goes from the 1 plug and splits into 2 plugs, i don't know where the smaller plug goes...
although dreaming about it last night, (which i seem to do alot unforunately) i was given the idea it may be something to do with a turbo timer maybe.... but my car doesn't have one.
It may have had one before you got it? Just a thought. Anyway, here is the ignition switch wiring diagram
I like pictures. Show me what your talking about. LOL
Sent from my Droid
someone had added the greddy harness for a timer at one point..... urg, i thought i had figured this out to. check my no power to ecu thread and see if you can help me their,
  • Wanted 6 bolt NT water pipe
    • chrisman287
