ignition problem?
goonie
251
4
Mar 2, 2004
soutomaior/spain, Europe
hi guys
i have some problems with my ignition when starting the car
first i tought it was the starter but after two different starters still the same problem
when i turn the ignition on i have to wigle the key to start the car
so what i want to do now is make a pushbutton to start the car
can you guys tell me which wire i have use to connect the pushbutton
thanks
well.... after a lot of swearing and lots of sparks flying around
i connected my pushstart button:D
so for any one who cares.......
at the back of your ignition there are a bunch of wires,
look for the black with yellow striped wire and the blue wire
connect those two wires to your push button
but do NOT CUT the wires from the ignition!!!! :nono:
if you cut them off it wont work(believe me i found out the hard way):coy:
just remove the insulation or get some t-clamps
good luck:thumb:
