Ignition Problem
starsthensun
116
May 1, 2005
Bay City, Michigan
I know this topic has been beaten to death, but im giong to re ask it. My car only fires on two cylinders right now ( 2,3.) 1,4 dont fire. what are some things I should test first. Also, is there a website or a past thread that shows the ohm/ volt readings and also how to check sensors. Im smart enough to put a motor together, but I still struggle with trouble shooting the motor if something is wrong. any help is greatly appreciated.
Another thing I dont understand is what ohm/ volt setting do i put it on for each sensor im checking...
I'm sure you've probably checked already but vfaq.com. Sounds to me like you've either got a bad coilpack (1-4 run on 1 and 2-3 run on the other) or a wiring/fuse issue.
