Ignition issues
bskills
53
May 11, 2008
Jersey City, New Jersey
Hi guys, Need some help here.
One morning I started my car and first thing is realized was that my RPM meter wasn't working. After driving for a few miles, my car started to run on 2 cylinders. Further checks revealed that #2 & #3 wasn't getting any spark. So far, I checked my ECU, injectors, Plugs and Wires, even changed my fuel filter and all are ok. Any input will be greatly appreciated.
on a 91+ the power transistor would be the only thing to drop your tach signal. even if it is firing a bad coil you'll get the correct tach signal.
The manuals show the tach gate on the output side of the transistor and I assumed it needed to see the pulsing 12v from the coils to trigger its signal. I guess it would be easy to test by just disconnecting the coil pack and see if you still get a tach reading on the gauge to prove one way or another if the transistor is the only thing that could drop you tach signal. I don't believe it is but I'm interested to learn otherwise.
yes that makes sense especially as the manual says when code 44 is present that it could either be the power transistor or coil.
I Just decided to post an update. In case anyone who sees this tread, they know that I was successful. I have been doing some upgrades to the car, but so far, everything is working good. About to get it tuned with ecmlink v3. Looking to for 400HP.
