ignition issues
DSM "BISH"
241
Sep 10, 2008
Erlanger, Kentucky
i need the firing order off the coil pack on my 1992 eagle talon with the 6 bolt 4G63t motor. i got new wires and the old ones where not labled correcly so i do not know how to run the new ones off the coil to the right cylinder. and also could i get the firing order of the cylinders and where it starts at.
thank you i just got a lot of work done to my car and im trying to start it and it started a few times but would sputter bad while running then die and it backfired through the intake once so i think my ignition wires are not in the right spot. and one of the wires the inside metal piece that goes in to the coil pack fell out so i pushed it back in and i think that is my problem of why the car is not staying runinng and sputtering.
4 3 2 1 <---- Timing Belt Side
4 1 2 3 Coil Pack Left to Right
Double check to make sure you have the wires right. That metal piece that is loose is probably not very good for getting a good connection. Maybe you can get a different coil pack to try.
You could also try checking the ohms of the coil pack by probing terminals 4 1 and 2 3 of the coil pack, i believe they should be around 12-13 ohms each.
