ignition issues
josherino
148
Sep 18, 2004
Ft Collins, Colorado
I have a hiccup at idle. I have replaced my spark plugs, used a volt meter to test my plug wires and just put a new coil pack in. What else could this be?
You might want to make sure that your plug gap is correct and that the plugs haven't loaded up from being run at too wide a gap. For your purposes .028-.030 would work fine. I had a similar issue cause idle misfire so check that first and then yell back at us.
Hope that helps,
Andy
they have been gapped at .028, I am not sure if I would call it a misfire, but a quick change in exhaust tone like a hiccup
I get that every once in a while. Does this also happen under WOT when you're mashing it under full boost? Are there any other hesitations under load?
Just wondering,
Andy
not only do I have hiccups at idle but under full load my car does a very extreme lurch, i am able to drive through it, and when I do it does it about 3 to 4 times before redline
Sounds more like a boost leak as opposed to an electrical issue. Possibly something small like TB shaft seals or a torn vacuum line. I would run a boost leak test and see if you can find any leaks.
Even a small vacuum leak can play major havoc with the performance of the motor.
Aloha
I'd have to agree with the above assessment and would go through the following checklist:
1. Boost leaks
2. Vacuum leans
3. Fuel pump - fuel pressure solenoid
4. Inspect ECU caps
Please have a look at all of those and let us know what you find.
Andy
