jonnyp777
- 0
- Sep 25, 2006
530,
California
Alright, long story short, driving one day, CEL, burnt up ISC driver on ECU, car won't idle. Don't know if it's from broken ISC or leaked capasitor, don't care, I bought a new ECU and ISC anyways. Put in new ECU with old ISC disconnected (haven't gotten new one yet), still won't idle, though ECU is still fine (I'm pretty sure). So when I do put in my new ISC, I'm guessing I have to do this crap below to run smooth again:
1g Idle & Timing Adjustment STRAIGHT FROM DSM MANUAL...
- Reset ECU 15 Minutes to clear all the crap out.
- With car off
- Ground that pin on the Diagnostic Connector
- Fully warm car up, No accessories on.
- Run at 2500 rpm more than 5 seconds
- Let idle for 2 minutes
- Adjust BISS 700-750 rpm
- Cut car off
-Disconnect Jumper at Diag Conn
- With Car OFF
- Connect Timing Jumper
- Fully warm up car - No accessories
- Check CURB IDLE is at 750 + or - 100 rpm (may take a little while to settle down being you just reset BISS)
- Set Timing at 5BTDC (which means you'd see 4 IMO due to bad angle)
- Cut Car OFF
- Disconnect Timing Jumper
- Cut car ON
- Check Basic Engine Timing 8BTDC (kinda jumps from 7-9 usually).
- AFTER setting Base Timing correctly per the above you could then "bump up" Base Idle a little (50 - 100 rpm) to help with the Fan cut-on - The ECU can pull more than you can retard! - Some of us have BOTH Fans cutting on simultaneously so that is loading your Alt more than a stock setup - Typically you can retard one degree when setting Base Timing & it idles smoother as long as Idle is close to spec - Setting it where you see 4 will make it more resistant to losing RPM when fans cut on.
Now, could some one please break this down for me. I don't get what half of that means. I have a manual, but am having trouble finding this stuff. Please no abbriviations, and tell me what each step involves, where to find the things I'm working with (Like what they are, where they are on the car, how I adjust them, etc.) and what I exactly need to perform these steps (like grounding stuff, do I need some wires or what, or do I just ground something that already exists on my car). I'm so confused at this point, that I am getting sick of DSM. I only bought one because it was a good deal, and I my civic had a bad paint job, and lots of other little things that bugged me. But if I can't get this crap figured out, I'm goning with a prelude, integra, civic, 240sx, whatever (I mean, I won't be losing much, I don't have a turbo like most of the people on this site anyways). So please, can someone help me out with detail please. Thank you in advance.
- With car off
- Cut car off
- With Car OFF
- Cut Car OFF
- Cut car ON
