Jiggalude
- 284
- 0
- May 14, 2005
Lancaster,
Pennsylvania
Alright, I've been looking for two days and haven't found any concrete answers. First off, the car runs great, when I first start it up, it ildes around 1000rpm. I eliminated all unnecessary vacuum lines today. I also removed the MBC and hooked the wga up directly the the vacuum source. I also boost leak tested it. When I run the car and boost it hits no more than 10 psi, so I know I don't have any leaks. I've got new plugs and wires, gapped at .030. Turbo is stock, fuel system is stock etc. etc. The only thing that isn't is the MAF-T. I have that set with all dip switches down, AUX. set to zero and base at 2, the other 3 are all zeros as well. It really sounds like it's cammed, but I know it's not because I actually turned the idle up by tightening the cable, and after the car was off and I turned it back on, it idled the same, so it's obviously a computer/sensor issue. Also, if I'm driving through my development and going down a slight hill in second gear, the car will buck slightly. Other than this, the car runs great.
No ideas?
No ideas?
changing the timing wont give you more HP 4g63s are 0 clearance if anything it will bend a valve
