mattp_65
Supporting Member
- 528
- 187
- Aug 16, 2004
Granite Falls,
Washington
Trying to do some idle tuning to get my 78 chevy Luv on the road (RWD 4G63T). Has 1g harness with 6bolt motor with 880cc injectors on SD. But for some reason it some times idle fine and then few seconds later just idles like crap and stalls out. Does my ISC or TPS look like its crapping out? I am running a 1g TPS with Idle switch wire connected. Any ideas? Also I have not set the timing yet to 5 deg since it keeps stalling.
. Sitting in the car running and having your changes take effect immediately usually gets me close if I don't have tried and true settings from the manufacturer of the injectors. Get that base idle set to 5* also, very important. I usually set the very first timing table box to 5* in my tune, to get started.
