420A Idle RPM at 1500 to 2000
Gothic_Tomgirl
Jun 28, 2021
El Sobrante, California
I have a 99 eclipse rs 2.0 n/t 5 speed I had a check engine P0171 light and replace all the the parts oxygen sensor, fuel injectors, vacuum hoses, spark plugs, wires and ignition coils.
I reset the ECU drove it for 30 miles and rpms still idle at 1500 to 2000... There no check engine light car is fine just high rpm. Also I let to car idle for another 10 minutes the reserve reservoir started to bubble and pushing ou the coolant..
What can the problem be now...
I checked the throttle cable it's good and there's no vacuum leaks either. Maybe it needs a new/used ECU?
Your throttle body gasket may be bad. I had that same issue back in 2006 on my 420a. The gasket is right after the flap and will act as a huge vaccum leak and the engine revs higher at idle to achieve optimal vac. At idle spray a little carbon cleaner at the TB gasket area if it revs up the gasket is toast and will need a new one.
I found the problem... The throttle body gasket was still good but, did put a new one just in case but, OMG the TB had alot of sludge built up. I cleaned it up and now it idles around 900 rpm now. Took it for a 20 mile drive and works like a charm...
The combination of a bad PCV valve and the EGR causes that sludge. Before I installed my aftermarket throttle body, I deleted the EGR and installed a new OEM PCV valve. Also did some major cleaning imif the intake manifold.
PCV valve dumps oil in there, then the EGR bakes it... I bet my runners are still as shiny as they were when I polished them without all that pollution.
