Idle issues
He is saying you probably have a bad idle speed controller (ISC), a dirty throttle body (TB), need to adjust your base idle set screw (BISS), or have boost leaks around your throttle body. He also asked if your check engine light (CEL) is on. (however it probably itsn't).
When you adjust your BISS you need to make sure that both the ECU diagnostic pin 10 and the timing check connectors are both grounded to a suitable chassis point. Then set your base idle, this disallows the ECU from moving the ISC to compensate for your adjustments. Having done that and the ubiquitous Boost Leak Test (BLT). Then I'd look into the ISC. You can ohm it out and see if there are an open set of coils in the motor. Unless I'm missing something, past that you ###### should remove clean the TB and possibly look in to a deeper issue being a FIAV, or some flakey sensor.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
