idle issues. please help
bOOTh_000
51
Dec 27, 2003
Calgary,
i have a 92 esi talon. runs fine until today. the car will stall at idle unless you give it gas. once its driving, its fine. also it used to have a bad idle when cold. the rpms would jump around and slowly come down.
anyone have any experience with this? i read it might be the isc...
any help would be greatly appreciated.
JOHN
JOHN
My guess is a vacuum leak (certainly as a first guess anyway). Try attaching a vacuum gauge to the PCV valve hose and see what it says at normal idle. Proper vacuum is in the range of 18 to 20 in-Hg. Much less than that indicates problems (also significant fluctuations indicate problems). I use this webpage to help interpret the vacuum guage indicator:
Intake Manifold Vacuum Tests
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
