Mytrn2brn
- 145
- 2
- Mar 11, 2006
buffalo,
New York
Hi Guy....
I've done all the research and I'm about to get to work. I've never done this kind of engine work. so that's why I'm posting before I have really done any work (don't want to screw things up to bad).
Here's the problem: When the engine is cold and i start the car. it idle fine, but when the engine reaches operating temp. The idle drops below 400. As long as the car is in gear, im good, but when i step on the clutch (as if im coming to a stop) the car dies and won't start back without me stepping on the gas.
I have changed the spark plugs and tomorrow I'll change the biss, fuel filter and PVC valve. I know that I have to check, test and clean the TB, ISC and IAC. Those are the part I don't have much experience with. I also want check my spark plug wires also, before I go out and buy more, but i don't know how to test plug wires to see if there good or bad, so any help there would be great.
Thanks
I forgot, car is a completely stock 95 gsx
Thanks
. But in all my experiences its probably a vac leak or iac needs cleaned. hope this helps.
