ID turbine housing
Not something you have. You're mistaking the 060 for 080 as your 78-11020 part number clearly depicts your housing as being 6cm.
The 8cm housings are very rare and are clearly identifiable:
None- to my knowledge it was intended to be a factory upgrade housing. It actually has a 54mm inlet, the same as a 14B or T25. :thumb:
The housing used in this example has the inlet ported to match a 7cm gasket (60mm), but you must be very careful porting an 8cm housing this far as you can easily port a hole right in the side of the housing. They also become much more prone to serious cracking when ported like this: http://www.dsmtuners.com/forums/turbo-system-tech/394644-turbo-housing-id-help-needed.html
