weapon_x
- 0
- Jan 2, 2003
The gains of an air-to-liquid intercooler on the street are slim to none. In most cases this type is used only for drag, marine, or space-limited situations. The liquid cooling it is the biggest problem. You can't just tap off of your existing cooling system because it operates at roughly 195 degrees F on a stock thermostat, and the ethyl glycol in coolant doesn't transfer heat well at all. This means that water is your only option, but this presents another problem. If a reservoir is placed under the hood it will heat the water thus losing some of it's cooling properties. Also, in order to pump the water you will need to run a 12V pump comstantly to move the water, and unless you drop some dimes on an expensive pump you will be replacing it often because most are not designed for that type of use. The size of reservoir is also important so that you don't run out of water and have a catastrophic, high-boost related failure. The gains from an air-to-liquid are huge (as in fourteenfold) over an air-to-air, but I don't think it is something that can be used constantly on a daily driver.
