IAC O-Ring Install?
AK_4g63t
100
Apr 21, 2007
Fairbanks, Alaska
So I just got a new IAC for a friend and I was going to throw it in his car tonight but this used one didn't come with any sort of o-ring. When i pulled his old IAC off there was gasket maker inside the hole and all over his old IAC. Does anyone know if the o-ring sits inside tight against the middle shaft or if it sits tight against the outer wall of the inner portion of the IAC or does it sit inside the throttle body and the raised edge of the IAC seals against it? Thanks.
-Donny
  • Wanted PASSENGER DOOR LOWER MOLDING
    WANTED
    • LA_gst
  • For sale 2g 2g 1999 eclipse gs-t spyder
    Very clean 2g spyder, only modifications is 14b turbo with 3inch exhaust. Well maintained and...
    • DSM B
  • For sale 2g 1996 Talon TSI AWD
    1996 Talon TSI AWD $10,500- 90,421 miles ( will go up a little ) - clean title in hand -...
  • For sale 2g 2g power window motors. OEM
    RH and LH power window motors. OEM $40 each or $70 for the pair. Message 702-741-6987.
  • Wanted WTB 268 Camshafts & Zero Tick Lifters
    Looking to see if anyone has a set of 268 cams in drop-in condition. I know 268 is on the Rare...
    • Ice9
